โMar-06-2017 08:33 AM
โMar-14-2017 11:09 PM
โMar-14-2017 09:42 PM
โMar-14-2017 09:16 PM
โMar-13-2017 06:05 AM
โMar-07-2017 09:53 AM
โMar-06-2017 06:40 PM
โMar-06-2017 12:36 PM
โMar-06-2017 12:15 PM
โMar-06-2017 11:50 AM
Chris Bryant wrote:
In a 2004, you may have a model with separate 120 volt thermostat and eco located on the back of the unit.
โMar-06-2017 11:49 AM
โMar-06-2017 10:18 AM
โMar-06-2017 10:13 AM
gillman wrote:if accessible from a cabinet its a plastic cover with two studs holding it on undo the nuts remove the cover everything is accessible if no way to get to the back through a cabinet then yes you have to pul the entire unit
Thanks for all the great information. What do I have to do to get to the backside of the Atwood should I have to replace the element? Completely pull the unit out? Any instructions on that?
Thanks again!
โMar-06-2017 10:11 AM
janstey58 wrote:
Old-Biscuit, thanks for this much needed info, mine also has gone OOS on the electric side. I also have a second issue, in that when using the water heater on gas, when I open any hot water tap inside my coach and run hot water, the water heater makes a loud whining noise. Any idea if this is related to the electrical issue, or do I have two issues? Thx, Jeff
โMar-06-2017 09:48 AM
