larry_cad
Mar 03, 2021Explorer II
dougrainer wrote:Dusty R wrote:
That switch should never need to open. If it does there is not enough air moving through/over the furnace.
They open and close all the time. OEM furnace ductwork installs NEVER match the correct volume of air required to run the furnace without the Limit occasionally tripping. Also the RV'er will block off some floor ducts to get more heat or air to some areas of the RV. That will also cause the Limit system to trip. YES, it would be nice if the Ductwork was installed to meet the Minimum requirements to prevent Limit switch tripping. I can ALWAYS make both Furnace and Roof AC ductwork many times more efficient, but unless under warranty, the customer will not want to pay for a check out and making it to best operation. Rarely do I get a complaint about Ductwork under warranty. They just figure that is the way it is. Doug
Great information. Thanks Doug
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
