rppartin0106's avatar
rppartin0106
Atwood HE-0601 Refrigerator
I have just installed a new Atwood refrigerator in my travel trailer and I have let it set over night. When turning it on I get a red check light. I have done what the manual says pushing down temp and mode buttons holding for 2 seconds and all of the blue lights flash in the panel. I don't know where to go from here, any suggestions are appreciated.
  • Atwood HE Model is not any different then a Norcold Or Dometic except that it uses HELIUM Gas vs HYDROGEN Gas
    It does have a built in 'Tilt Monitoring' and the 'CHECK' fault light indicates more then just an issue with propane not lighting.
    Below ae ERROR Messages for that HE Model
    ERROR MESSAGES --------INDICATOR--------------DESCRIPTION
    CHECK light
    Slow beep------------Door Not Closed----------Close Door
    Once every 2 sec
    CHECK light
    Very Slow beep-------Back Up Operating MODE---Replace Thermistor
    Once every 10 sec----Thermistor damaged
    Temp Set LEDs
    all flash when-------Back Up Operating MODE---Replace Thermistor
    switch is pressed----Thermistor damaged
    CHECK light
    GAS light on--------Burner failed to light----Retry
    CHECK light
    GAS light flashing---Gas unavailable----------Gas ON
    CHECK light
    AC light flashing----AC unavailable-----------AC On
    CHECK light
    AUTO light-----------1. Open DC fuse---------Replace Fuse
    AC light-------------2. Open thermal switch--Cooling Unit Tripped
    ALL On---------------3. Prolonged operation in severe tilt position
    Here is a more in-depth troubleshooting guide
    https://www.manualslib.com/manual/1067876/Atwood-He-0601.html#manual
    Check the 'diagnostic' mode
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
