jege41's avatar
jege41
Atwood HW tank to Dometic 6 gallon propane only
Hi
I'm replacing a 2006 Atwood propane only 6 gallon hot water tank to a new Dometic 6 gallon propane only hot water tank. The install was fairly straight forward however the thermostat isn't shutting off the burner.
Yes the wiring is correct as I had the chance to check it with the volt meter yesterday. I am thinking my unit may have a faulty thermostat as the water temperature seems to peak at around 165F which is scolding and the ECO kicks in and shuts the unit down. Could I have a faulty thermostat and a bad mixing device, or could it be the board. I have sent Dometic support an email but have not heard anything back from them yet.
  • Hi Doug
  • OK on RV's WHITE is almost always Ground(neg).
    So, on a Atwood LP only with electronic ignition
    Green Is Ground
    BLUE goes to the inside switch and is the wire that turns on the Red light that indicates failure of lighting
    BROWN come from the wall switch, so Brown and RED should be the same wire.
    The 12 volts going to the water heater is supplied AT the inside wall switch. So, on the back of the wall switch you should have that Brown which will have 12 volts WHEN the inside switch is turned on. There should be 4 wires at the back of the wall switch. BLUE which goes to the Water Heater. Brown which goes to the water heater. Then the WHITE which supplies ground for the wall switch light and then goes down to the Water Heater.
    Regardless, IF the Water Heater lights, It has 2 tstats(140 degree and at 180 ECO) that will kill power to the control board to turn it off when temp is reached or fails to shut down from first tstat. Miswiring the wiring, it should NOT have ignited and if it did, then the wiring is probably correct. What makes you think the tstat is not shutting off the burner? Is it shooting water out the pressure valve? Doug
