Adventurer_Buck
Apr 04, 2016Explorer
Auto Levelers StabilizerJacks: All 4 down when Leveled?
Class A Winnebago Adventurer Ford F-35, V-10
Are all 4 Auto Leveling Jacks suppose to make contact with the ground when the motorhome is fully leveled?
When leveling, the back "passenger" side Jack extends down, touches the ground and levels. Yet when the "driver's" side rear Jack extends downwards and lifts the "driver's" side rear to find level, the "passenger's" side Jack that was on the ground, lifts off the ground yet does not re-extend to make contact with the ground. There is more shaft to extend in the "passenger's" side Jack.
The motor that extends the Jacks "whines" at the end of the leveling cycle for what seems to be a longer period than needed...like it's trying to extend the Jacks more (maybe the "passenger's side rear Jack). The Jacks control panel registers a green light at the end of the cycle saying all's leveled. All Jacks retract as designed when the command for "Jacks Up" is called for.
The questions: "Are all fours Leveling Jacks suppose to be in contact with the ground at all times when "Jacks Down" is engaged?"
Thank you for your responses.
