mlts22's avatar
mlts22
Batteries and acid shipped in different containers?
Right after each other, both the recoil rope broke and the starter battery of my 3000 watt Yamaha generator died. Rather than disassemble the darn thing to get a new pull rope added, I went and replaced the battery with a Yamaha motorcycle battery, which fit in perfectly, and had the same amp-hours as the old one.
Oddly enough, the box shipped with the battery, and a row of six vials of acid attached to each other. To get the acid in the battery, one pulled a sticker off the battery, turned the acid vials upside down, placed it over the row of holes on the battery, pressed to punch the foil seal on the vials, squeezed the bottles so the acid drained completely into the cells, then yanked off the row of vials, and then pressed a cap that spanned all six holes into place.
Took a few minutes to do, and even though the operation was fairly safe, playing with battery acid in the middle of the woods isn't my idea of a good time, even with making sure I had access to water and was wearing eye protection.
Is shipping acid separately from the battery something new that battery makers are doing? This is the first time I've seen this.
