time2roll
Feb 05, 2019Nomad
radar46 wrote:In use or just in storage?
Is there any danger of battery damage in outside temps of
20-30 degrees (F) in my 5th wheel Cougar? The two 6 volts
are enclosed in a thick case with a blanket over the case.
No heat in front storage.
Thanks,
Warren.
Storage... charge 48 hours and disconnect. Fine until spring.
In-use... best to plug in every day to get charge back up. Could freeze at 12.0 volts. I would be charging at 12.4 maybe 12.3 at the lowest.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
