popeyemth
Jul 20, 2013Explorer
Yes the TT converter should do that
Get a cheap Multi meter and check the batt voltage, then plug to shore power and check again.
If the converter is charging the voltage should go from 12 volts to 13plus
You need a meter anyway .
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
