pianotuna
Dec 25, 2014Nomad III
Hi,
3 amps corresponds to about 36 watts. 5 is more like 60 watts.
Under charging still applies as you don't have enough solar wattage to fill the batteries. AGM do require higher voltages--but as I said before check with the maker.
Fully charging is going to take far more than 3 hours. Only two ways make sense to do so. Shore power, or enough solar.
