twvette
Dec 24, 2014Explorer
Batteries/solar not holding up, troubleshooting help please
I have no luck getting batteries to hold up it seems. Had a couple different RV's and different setups too (wet cell, lifeline golf cart, gel deep cycle batteries)and none have ever held up well.
Anyways, here is what I have now:
- Onan 5500 gen
- Iota DLS-45 converter
- Three Optima Bluetop D31M (less than a year old)
- Large solar panel (or maybe it is even two combined together?)
- Shell Solar RV 20 solar controller /monitor
- Only camp in AZ so almost always get great solar
Worked great in beginning but seem to be on downward spiral. I now can't get through even a mildly cold night (mid 40's) of heater use only without them dying. I have had to run the generator much more even with the solar system to get/keep them fairly charged whereas before the solar panel would generally give me full recovery from typical day and night use.
Here are some observations:
- I previously got 13.4 volts or higher when running the generator but now only see 13.0, and settles at about 12.7v a little while after shutting off generator
- When shutting off generator I never get much more than an "OK" status on my monitor whereas as before I would typically be at "GOOD" or a few LEDs above at least for a while
- Connected an automotive style battery charger after charging with generator for a while and it also claimed the batteries were fully charged.
Here are some questions/concerns:
- Is the solar system overcharging my batteries slowly killing them?
- I do not have the Iota IQ4 smart charge option as far as I can tell, perhaps this will help? Seems like a long shot as had this in previous RV and did not see any real improvement but maybe would prevent Onan 5500 from improperly charging gel batteries this time around?
- Generator/Iota DLS-45 issue in general? All my RV's have had this same setup
- Is the Shell Solar RV 20 junk or good? I did not purchase or install this system.
- Can anyone tell from pics below which solar panels I might have? I have no clue on make/model/output and no markings on them even underneath!
- Maybe I am leaking back power through the solar panels at night?
- Would putting an ammeter inline help figure this out? Maybe a Doc Wattson http://www.rc-electronics-usa.com/ammeters/rv-battery-monitor.html
- How to test my batteries to see if they are still good? Maybe only one battery is bad?
Thanks for any help!
- Onan 5500 gen
