S_Davis's avatar
S_Davis
Battery box vent size?
I am installing an inverter system on my truck, it has two separate battery boxes that will hold three Lifeline GPL-30HT each for a total of six, one box will vent to the other and then that box vents to the outside of the cab, What size vent should I run?
1 Reply
  • Here is an example of what you need.battery vent kit
    AGM batteries are normally sealed and do not require venting.
    I would use two separate venting system and not connect together for vented lead acid batteries.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
