Hello all, new to the forum and I have a question errr, problem. Whenever I plug in my TT, either house electric or plug on my truck, the fuse to the battery pops. It's a 20 amp fuse is this correc...
What converter do you have? The last two digits of the converter model are generally the max output amps of said converter.. So if your converter is say a xx35 then a 20 amp fuse is gonna flashbulb on you... (you need a 40).
Mine is a xx80, and so is the circuit breaker that protects things.
NOTE: for this post ONLY the model number is important, the make is not.
