RoyB
Dec 14, 2019Explorer II
I built a monitor panel up suing one of those three position light switch plastic panels... Have three meters glued to the panel..
This monitor the DC VOLTS coming from my two batteries groups and DC AMPS feeding my setup.
The two DC VOLTS will read the same DC VOLTAGES if both battery banks have been selected. Sometimes I will be using One battery bank while I am charge the second battery bank...
I like to monitor the 12VDC Battery voltages when camping off-grid so that I will not want to go below the 12.0VDC level which is approximately the 50% charge state of the batteries... When this happens I want to be start my battery charge operations as soon as possible using my 2KW Generator setup. Most of the time I do the three hour charge mode starting around 8AM each morning during our breakfast time...
I have this panel mounted on a side panel just as you enter my off-road POPUP camper...
![](https://i.imgur.com/76Z3Vqc.png)
Roy's image
![](https://i.imgur.com/tjWzR1M.png)
Roy's iamge
Roy Ken
![](https://i.imgur.com/SoQ6BfGm.jpg)
Roy's image
Roy's iamge
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
