ksg5000
Apr 29, 2013Explorer
Had similar problem -- my solenoid was in engine compartment - my fix was to run a wire from E350 fuse panel through a rubber grommet on fire wall to the solenoid. I purchased one of those piggy back fuses and used the radio slot as it is energized when the ignition key is turned on. 5 minute DIY job.
