monkey44Nomad IIOct 03, 2016Battery test ?I believe I have a battery that is not charging - at least it's not holding a charge (Interstate 27 - five years old) ... I need to see if the truck is charging the battery before I spend the money...Show More
Dave_H_MExplorer IIOct 04, 2016Can't you just run the truck at high idle and stick a volt meter on the batt terminals?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
Related ContentBattery hydrometer testing questions...Toilet paper testtesting sig picTest drive test tow?Pressure Tested Camper Leaks Found
