Feb-04-2017 07:18 AM
Feb-05-2017 08:05 AM
BoonHauler wrote:
I just ran across your thread, nice shop setup!!
Feb-05-2017 08:03 AM
Kayteg1 wrote:
Snip..
I am a welder when I need it and as I mentioned- probably the best fix is add welded plate on the side of I-beam.
Question is how to get the beam straight, or preferable bend other way for the time of the welding?
Will the center of the beam sag, when you jack up the ends?
In the past I was using 2x8 C-channels as ramps for equipment loading.
But one of those 10,000lb backhoes bend the chanel.
My reinforcement was adding welded rebar on the tips of C. But I did not have 10k press to straight it before reinforcement.
What I did was weld one end of the bar to the channel, than with torch warm up the bar in the range of 600F and then quickly weld the other end of the bar to the chanel.
Than I did 3" welds every foot.
Rebar when cooling down, shrank and pulled the chanel straight.
Obviously having trailer on the top of the chanel makes using torch a danger job, but similar effects can be done with cooling.
Feb-05-2017 05:33 AM
dougrainer wrote:
No, not that one. There are 2 sheets. The 0104 and the 0135 rev A that address your issue. Doug
Feb-05-2017 05:15 AM
JBarca wrote:dougrainer wrote:
Doug wrote:
There is NO obvious bending or damage when the Frame is flexing. That is why you do the Camber check out procedure.
What I meant was, On the units I have inspected for LCI to repair (about 10 over the years), there is no obvious damage or bends you can really see. Once you get the procedure (LCI Lip Sheet 0104 Camber measurement procedure), you will see. Doug
Thanks again, now I have something to ask about.
By chance do you know if the 0104 LIP Sheet was replaced with the 068? This one? 068 Frame Camber Measurement Procedure
The 0104 sheet does not show up on the LCI site but the 068 one does. The 068 sheet is basically measuring frame sag across the length of the camper. The 2 fixed bars need to be the same length clamped to the bottom of the frame rail low enough be be below the axle tub and a string pulled between them is the straight line. Then measure from the line to the frame at the locations they are listing on page 4. This is not hard to do.
I already know the back of the camper is 3" lower then the rear hanger location on the slide side. The door side, is equal at the rear hanger and the end of the camper.
Thanks
John
Feb-04-2017 01:50 PM
Feb-04-2017 01:22 PM
Feb-04-2017 01:04 PM
Feb-04-2017 12:36 PM
Feb-04-2017 12:06 PM
Feb-04-2017 11:32 AM
dougrainer wrote:
I don't think you understand the problem if the frame was not built correctly. There is NO WAY LCI can state that the Gauge/Grade of steel and the DESIGN will function for your particular model. LCI has no records of what frames and what OEM's had problems. You must do a specific LCI check sheet. Unless you get that from LCI, a phone call will not get you help. It appears you have the knowledge and can build the tools(about $10 worth) to do the measurements LCI will require to get better info to you. So. Monday, get LCI to Fax or email you the frame camber check out sheets. There is NO obvious bending or damage when the Frame is flexing. That is why you do the Camber check out procedure. Doug
Doug wrote:I fully agree the frame design did fail under load. But the frame is bent and there is damage to the lower flange where it is bent. Right behind the hanger.
Feb-04-2017 10:13 AM
Feb-04-2017 09:41 AM
marcsbigfoot20b27 wrote:
From those pictures it almost appears that there was a tire blowout that slapped the heck out of the frame....weakening it and it started to droop.
Feb-04-2017 09:30 AM
Kayteg1 wrote:
Welcome to the RV World.
Everything is build to minimum standarts unless you can afford bus conversion.
That said, this bend doesn't look like coming from load stress.
More like hitting something or wrongly positioned jack.
I think jacking frame straight and welding plate to close I into square tubing would be the best reinforcement.
Feb-04-2017 08:57 AM
Feb-04-2017 08:39 AM
dougrainer wrote:
Do you know if you have a LCI(Lippert) Frame?
LCI builds the chassis to the OEM engineers specs, NOT what LCI engineers it. I have seen (Master tech) dozens of LCI frames that do what yours is doing over the years. The problem is, they do NOT build the frame strong enough for the Hole cut out for the slide room. That causes the type flex you have experienced.
Usually what causes the customer to notice the problem is when they have numerous issues with the operation of the slide room. It sticks/jams/ will not go in and out correctly.
