bighatnohorse's avatar
bighatnohorse
Mar 19, 2019
Bezel for covering screw holes?
Is there such a thing (and a source for) a "cover-up" plate?
I might want to mount some hardware and remove it later and would prefer to have a cover plate of some sort to cover up the screw holes left behind.
  • Have a look at peel & stick "covers" from Fastcap.com They come in various colors, sizes and shapes and are quite thin. I used some wood-colored ones in our TT to cover screw holes in the cabinets. Inexpensive, easy to use and available all over the place.
  • Small holes from mounting a CB radio.
    Looks like the plugs would work! Thanks for that!
  • How big of a holes are you talking about?? Tiny screw holes, or and 3-4 inch cutout??
  • They make little plastic 'plugs' to do that. They look like small mushrooms, the flat disk lays flat against the wall while the 'stem' pokes into the hole and keeps it there. I have no idea what the official name is but they have them at the big box hardware stores. Or you could use spackle, but that has to be sanded flush and painted.
    I am a master of search; look here or, here.
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
