jdc1
Jul 13, 2020Explorer II
If you're trying to get the glued ABS sections apart, in the construction trades we use a small grinder with a diamond blade. We cut the overlapping section just deep enough to touch the inserted part. Make 5-6 cuts. Then use a small (1/2") chisel to remove the overlapped ABS fitting. Sand down the left over particles/glue, then start glueing the new parts in place. Be sure to use glue on both male and female parts. It's a pain working on your back, but it's a lot cheaper than having someone do something this simple.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
