shanedank187's avatar
shanedank187
brand new battery 12.7 v..not getting power to the coach
used a volt tester the battery is brand new and fully charged, but for some reason, its not powering the rv, when i installed the new battery, went camping, turned on a few lights, instantly the lights shut off, when i had one on it was ok, put 2 on it would kill all the power, the weird thing is, when the lights came back on they were bright, not dull, also when i plug the rv into power or generator its fine. what could this be??
  • Sounds like a baaaaaaaaaaaaaaaad connection. Start right at the battery. Do not be fooled by "new" looking connections, you have a loose or corroded one somewhere. The negative "ground" connection is infamous for causing this symptom.
    Plugging in you create an alternate BATTERY complete with ground.
    Your battery has a bad connection. Go for it.
  • The battery(s) ground on the "NEG" post of the battery. Did you remember to re-attach the grounding wire?
    If you grounded the "POS" post you re-installed the battery(s) back-words. It may blow the fuse on the converter/charger if left that way.
    If two 12v batteries, are they connected in parallel? Two 6v volts must be in series.
  • You said...."when the lights came back on they were bright, not dull..." How is it that they come back on? Did you reset a breaker, or do they come back on by themselves after you turn off the extra lights? I suspect a loose connection somewhere if it's the latter. Make sure battery terminals are clean, free of corrosion and connections are tight.
  • did you hook up the battery with the polarity reversed? do you have a battery disconnect switch that is off?
