wnjj
Aug 13, 2015Explorer II
Barkoff wrote:
I fired up the unit and waited for ten minutes inside the camper, and was not getting any cold air.
I turned it off went topside and inspected everything, it all looked OK. Fired it back up and went up topside again. The fan ran for at least ten minutes before all of a sudden the compressor clicked on.
To clarify here: Did the compressor not start until 10 minutes after the 2nd time you turned it on? My Mach A/C turns on pretty much immediately when I switch the t-stat to cool.
Does the compressor stay running the whole time once started or is it shutting back off?
