Has anyone used a bus bar to reduce the wire clutter at there battery's? I have to unhook my battery's for winter storage and was thinking it would be a lot less hassle to only deal with a couple wire...
No reason you can't do that as long as the positive bus bar is covered/protected to prevent accidentally shorting it to ground. I have not done it. My battery only has a single wire to each post and is distributed down stream after auto reset circuit breakers.
