portscanner's avatar
portscanner
Busted radio antenna - Need help finding a replacement!
The antenna that is connected to the radio in the dash (for the driver) got busted. This antenna is mounted on the roof of the RV (not on the cab) so it is not from Mercedes Benz.
The base of the antenna is a female 10-32 threaded hole - and is not damaged - I just got to get a new "stick" with male 10-32 threads to screw in.
Looking on line for replacements, all I can find are listings that say for make/model/year, such as "for Ford F150 20XX-20YY" I cant find anything where there is a listing where it indicates the thread size.
Anyone have a suggestion?
  • The antennae on my used Rockwood was missing. I added a new one with a spring in it so it can bend going under trees. The cost about $15.
  • Sounds the same as mine. Found replacements for mine in most any car part stores including wall mart.
  • it's been years ago but I got a replacement from a auto parts store
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
