Almot's avatar
Almot
Feb 22, 2015
Cable routing - conduit fittings?
I'm humbly asking advice from electricians and other DIY/reno etc people here.
Installed solar controller on the bedroom wall next to night-table. Didn't want it there, but with limited through-storage and recent floods, had to let this guy in :s
Breakers box and AGM battery bank are in under-bed through-storage, night-table is the ceiling of this storage, so battery is "close-ish" to controller. Pos wire from battery to controller via Pos bus is total 9.5 ft. Neg wire from trailer frame to controller via Neg bus is same 9.5 ft. Max current of controller is 30A, unlikely reached at sea level. Calculator for one-phase AWG 6 wire @10ft, 14V, shows 1.9% V-drop - fine with me.
Photo below: Big Baby breakers box in through-storage. Batteries are across the Baby on the right (not shown). Ceiling is the night-table, controller is on the wall few inches above the "ceiling".
Possible fittings on breakers box:
  • Wires from battery enter the box via 3/4 opening at the top - where blue fitting is.
  • Pos wires from controller -> through the storage ceiling/night table enter/exit the box via 3/4 hole, where grey cord grip is sitting.
  • Neg wire from trailer frame and Pos loads enter the storage via the hole in floor -> then to the box via 3/4 opening marked with red circle.
    Q1: I like grey strain relief connectors. But I also like conduits. Can't have both, can I?
    Plan:
    Keep strain-relief as shown, for 1 ft run to controller in split-loom to the storage ceiling hole via rubber grommet (and then Wiremold duct in bedroom).
    Battery cables from Baby box - again strain-relief and split-loom.
    Pos/Neg loads from red circle to the hole in storage floor - in a conduit.
    Q2: What fitting or nipple can be used for Pos/Neg cables from "red circle" in a conduit through 3/4" floor? Or at least 3ft conduit from the Baby box to the hole in the floor. I prefer a good conduit like Liquidtight, as Neg cable to frame is potentially 30A current, and storage will be used as a storage, with tools, pieces of lumber etc thrown in and out. Though blue corrugated ENT "hose" would probably suffice.
  • About Technical Issues
    Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
