taken
Apr 11, 2015Explorer II
Can anyone help with a load management center issue?
New RV has three AC's so a load management system is installed with it's monitor panel in the closet near the breaker box. It is a Precision Circuits Inc. unit. I can't find the exact model number on their website. All the units they show are two ac's, hot water, and fridge. Mine is three ac units and HW. Looks mostly like this but with three ac's instead of the fridge:
Anyways, I just noticed that when plugged into 50amp, my panel was showing 30 amp available. I can press the select button and go back and fourth between 20 and 30 but it should show 50. My first thought was the rig was wired wrong and all circuits were on the same leg. (I know my 50 amp service is good as it's at my home.) However after some quick experimenting, I found another oddity. If I turn off the breaker to AC number 2 which is the front bedroom ac, the panel switches to 50 amp. Turn it back on and it drops to 30 Amp. This is with all ac's off. Just turning the breaker on and off. Turning the breaker for ac 1 or ac 3 on or off has no effect. It's only number 2 that changes the readout.
So, I'm very good with electrical and one of my best friends is an electrician but this is beyond my ability to troubleshoot without some guidance as it's more RV system specific than wiring specific. Any help would be appreciated.
PS: I did place a call to the RV manufacturer and to Precision Circuits Inc. but since it was 3 o'clock on a Friday when I noticed this, PCI went to voicemail and the manufacturer's installation tech had gone for the weekend.
