ShoelaceExpress's avatar
Mar 29, 2017
Can I charge/maintain 12V batteries in parallel?
We had an older pop-up, but never had a battery on it. We recently upgraded to a 31' Bullet Premiere 31bhpr. SOOOOO HAPPY RIGHT NOW! haha.. ok, onto my questions about charging/maintaining:
The new TT needed a new battery, so I ended up purchasing two deep-cycle RV/marine batteries to install in parallel. I haven't hooked up the batteries yet, but will shortly.
1. I have a 12v battery charger/maintainer at home. Is it possible to hook the two batteries up in parallel in my garage and charge/maintain the batteries like that? Or should I just go buy a second charger/maintainer?
2. For while camping, I bought 2x40W Coleman solar panels (80W total). I need to find a iMob 4-in-1 connector so I can add both 40W panels together before the 7A charge controller - does anyone know where I should look? I've found them for $7 online, but they want $25 shipping to Canada.
3. Since the batteries will be in parallel while connected to the trailer, is it ok for the solar panels / charge controller to be connected to the parallel batteries, or should I disconnect one at a time and charge them? Alternatively, I could disconnect them from parallel and use a panel and charge controller (since I have two of each) on each battery. Just wasn't sure what the proper charging technique is.
Thanks!
