โMar-12-2018 08:17 AM
โMar-25-2018 09:23 AM
โMar-25-2018 08:20 AM
โMar-25-2018 06:37 AM
โMar-23-2018 04:27 PM
โMar-23-2018 02:39 PM
โMar-23-2018 02:25 PM
โMar-17-2018 08:19 AM
โMar-17-2018 06:08 AM
mrekim wrote:
I just replaced a tank. Some helpful hints:
1) Get a grinder or dremel to cut the old rings off. Tin snips don't work well...
2) Make notes of all the wiring connections - photos too.
3) You can make a tool for putting the new rings on from a piece of PVC. Get one that's a little too small and then use a heat gun to make it flexible and form it over the tube.
4) Use a drift to snug the rings down once you get them most of the way with the PVC. If you get the PVC stuck you can probably use channel locks to pry it off or heat it back up.
โMar-16-2018 08:25 PM
โMar-16-2018 05:47 PM
โMar-16-2018 07:46 AM
โMar-16-2018 07:41 AM
Lantley wrote:dougrainer wrote:
Atwood water heater tanks are constructed of a high strength aluminum.
The interior of the tank consists of a .0015 thickness of type 7072
aluminum (pure aluminum and zinc) that is fused to the core during the
rolling process. This material protects the tanks from the effects of heavy
metals and salts found in waters throughout the country. It is anodic to
these heavy metals and acts much like an anode in a steel glass lined
tank except it will last much longer. Aftermarket Anode Rods are not
required and should not be used and will void warranty
I'm curious, As an RV tech what is your take on replacing just the tank and swapping in the controls vs. replacing the entire unit?
โMar-16-2018 06:05 AM
โMar-16-2018 05:08 AM
