greenrvgreen
Aug 19, 2014Explorer
Charger: Meanwell 10a or Iota DLS 15?
This is a followup to the thread I posted a couple weeks back. I want a capable portable charger for a 100ah AGM battery bank, mostly fed by solar. The constraint is that my generator is limited to 450 watts output. The max draw of the DLS 15 is 400 watts (3.7a @108v), while the meanwell appears to draw 350 watts. Both are fine in that respect.
My question is, which will give me better charging performance? I can set the meanwell to a high voltage (14.5 or higher), but I am limited to 10a. The dls 15 will go to 14.8 if I let it (14.4 normally), but its internal logic will decide the charging voltage. It appears to charge at 15a throughout, as long as the amps will fit.
The Iota is more than twice the price, but 50% more amps. Will I get 50% better performane, even though the volts will drop down?
Thanks!
Thanks!
