DaHose's avatar
DaHose
Charger Upgrade Question
Hey everyone. I am looking to add big battery capacity to my RV and the question of a charger upgrade has me a bit "perplexed". If you installed something like a Progressive Dynamics 9200, did you buy a unit that slides in and replaces your existing charger module or did you get the one that plugs directly into 120V with a traditional cord? I have been looking around and it seems PD doesn't make the 100A units in the form factor that slides into the OEM location. If you installed a 100A 9200, did you just ditch the built in unit from the bottom of your power center, replace with the 9200 and run a new cord to a 120 outlet? Or do you re-use the 120V feed to the OEM unit by putting a female socket on the cables?
For the curious amongst you, I plan to run a new set of 4 gauge wires directly to the new 6V batteries (in series for 12V) as well.
Jose
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
