SpeakEasy
Aug 08, 2018Explorer
Charging a 12V AGM Battery
I've been researching various options for replacing my Walmart 12V sort-of deep-cycle battery. I've pretty much decided that a single 12V AGM would be the right choice, given my budget and electrical usage.
My question is about charging.
I currently have a 100-Watt solar panel and a Morningstar SunSaver PWM controller. The controller came with instructions for setting it up for EITHER a "sealed" battery type or a "flooded" battery type. There is a jumper that is installed between two terminal blocks if you want to set it up for a sealed battery. You do not install that jumper to use it with a flooded battery. I did not install the jumper.
If I buy a 12V AGM, do I just install that jumper and go on with life? Or is there more to properly charging a 12V AGM? What about the times when I have to use the generator for charging? Does the trailer's converter need to be replaced in order to do this? If I plug in to shore power and there is no sun, will the existing converter be OK?
Thanks in advance.
-Speak
Thanks in advance.
-Speak
