no-logic
Aug 10, 2018Explorer
shastagary wrote:Yup. Converter still works. Just won't charge the battery. Same issue I had with it the first time.
your wfco converter does more than just charge the battery it supplies all the power for your 12v devices when you are plugged in does it still do that and the battery is not charging?
if it still powers your 12v needs i would leave it in place and use a separate charger at the same time to help charge the battery until you can replace it.
if your battery was dead it will take more than over night to recharge it if it is still good.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
