- spud1957Explorergot my answer
- bikendanExplorer
spud1957 wrote:
Lazy question before I take the generator out to the trailer.
Will the battery charge when I have the disconnect off?
No, if you connect the shore cord to the generator.
Yes, if you connect the generator's 12v cables directly to the battery. BUT this is the most inefficient way to recharge the battery. - MEXICOWANDERERExplorerConnect charging cables direct to the battery. If you are using the shore power to connect AC and charging via the onboard converter, it won't charge. You would have to engage the battery cutoff switch first.
- Bring your voltmeter and verify right on the battery terminals. 13.2+ is charging. 12.8 or less is not charging.
- BFL13Explorer II
No if using the converter, yes if using a portable charger clamped to the battery
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 25, 2025
