ezgoin
Sep 15, 2020Explorer
Check fuse in Ford Power Distribution Box
Hi all,
Just drove 2 days from Phoenix to Colorado with new Stay-in-Play break controller and arrived with a dead battery on Jeep Wrangler. Called installer and he said to check 30 amp fuse on coach that feeds power to tow vehicle. Coach is 2014 Ford F53. Manual shows fuse 13 is 30 amp “Trailer Tow Electric Break Controller Feed”, so I assume that’s the one I need to check. It’s under the hood of the coach in the Power Distribution Box which says to disconnect battery cable before removing the cover to expose fuses. I’m not the most tech savvy person around so I don’t feel comfortable trying to open (and not be able to close) the cover.
Since Jeep battery was dead I had to replace it because it couldn’t hold A charge after jumping it. Now I am concerned that if I can’t check the fuse i will end up having to replace a new battery if it dies going 2 days back home.
Suggestions?
Bill
Suggestions?
Bill
