City water hookup leaks
jornvango
While boondocking, I noticed the city water hookup is leaking. We haven't used that hookup in about 5 months.
Could it be a seal in the city water hookup? I'm not sure how that hookup is connected plumbing-wise and what normally stops water from coming out of that hookup while boondocking with the water pump turned on and the system pressurized.
2009 Casita travel trailer
Thank you!
18 REPLIES 18
jornvango
Per the Casita service department, it is a rivet, not a screw. Doh!
That being said, I cleaned it out and it's not leaking any longer. I think washing the trailer with high pressure must have moved the rubber seal.
Thanks!
Community Alumni
Not applicable
Ooopppps
Ron3rd
jornvango wrote:
Thanks!
First I have to find the tool to be able to detach the hookup! I thought I carried a bunch of screwdriver heads but the screws on the hookup look like something I haven't seen before. I'm not sure if the screws are standard across RV brands but mine looks like it needs a 'tri-wing' head. (which I don't carry)
Only 2 I've seen on my last 3 trailers are the square drive or Phillips head.
Equilizer Hitch
Honda EU2000
capacitor
A torx? It is star shaped. A Robertson is square.
jornvango
Thanks!
Ron3rd
Beverley&Ken wrote:
There is a one way valve just inside the city water hookup, actually it is part of the hose input. Inside the fitting is a one way valve that sometimes becomes dislodged, Most common after winterzing.
The part us not expensive, approx $10. Easy to replace, on the outside of the RV, remove the screws holding the inlet, pull out slightly and replace with the new. New caulking and done.
Ken
This is true; and they make an all plastic version (which your probably have) and a superior version with a brass connection at the backside.
Equilizer Hitch
Honda EU2000
2oldman
Dutch_12078 wrote:
a quick temporary fix is to just screw a garden hose plug into the fitting.
That's not a temporary fix, that's permanent! ๐Ÿ™‚
Dave_H_M
Dutch_12078 wrote:
If flushing the check valve doesn't fix it, a quick temporary fix is to just screw a garden hose plug into the fitting. If that's not on hand, an inline garden hose shut off valve or even a common 'Y' adapter with shut offs will work.
Yep I carry one of those just in case. That was after the school of hard knocks. ๐Ÿ˜‰
Bobbo
agesilaus wrote:
Are you guys saying that the fresh water tank is pressurized?? I doubt it. The pump takes a suction on the tank the water is pulled thru the pump and comes out pressurized.
No one has said that. The water line between the water pump and the faucets is pressurized if the pump is on, or if it holds pressure when the pump is turned off.
Bobbo and Lin
agesilaus
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Community Alumni
Not applicable
Bobbo wrote:
wa8yxm wrote:
JimR 1 wrote:
When mine leaked it was some sand or crud that got in the valve on mine there is a stem inside that I push in against the pressure and that flushes the valve out.
But I have also replaced two
JimR
The "I have no clue where they got their brains from" folks will holler that "OH you will break it if you do that" (Not true) but here is a fact.. It's already broken.. You might fix it, or you might not but worst case is you don't fix it
You depressurize the system first. If you don't, there is a CHANCE that the ring washer will be pushed out of place. Not always, but sometimes. If you depressurize first, there is not enough force to push the ring washer out, but you still get water backflowing out of the valve.
Yes I was on tank water pump off. I discovered the leak when after filling the tank and removing the water hose that the pump would not quit running so I turned off the pump and went to look. Not sure what I had there for a plug, must have been a push in type no threads. The problem was some hard water, calcium, from the campground faucet went through the hose into the valve and I could see it sticking out the valve pushed the little pin and all was good.
Glad I caught because the campground had shut the water off after my fill cold night Dec 31st Bosque Birdwatchers RV Park, San Antonio NM.
JimR
Dutch_12078
Dutch
2001 GBM Landau 34' Class A
Bobbo
JimR
Bobbo and Lin
wa8yxm
JimR
