โApr-29-2021 07:19 PM
โMay-10-2021 02:07 PM
โMay-03-2021 06:28 PM
โMay-01-2021 08:32 PM
jornvango wrote:
Thanks!
First I have to find the tool to be able to detach the hookup! I thought I carried a bunch of screwdriver heads but the screws on the hookup look like something I haven't seen before. I'm not sure if the screws are standard across RV brands but mine looks like it needs a 'tri-wing' head. (which I don't carry)
โMay-01-2021 04:12 PM
โMay-01-2021 03:15 PM
โMay-01-2021 11:57 AM
Beverley&Ken wrote:
There is a one way valve just inside the city water hookup, actually it is part of the hose input. Inside the fitting is a one way valve that sometimes becomes dislodged, Most common after winterzing.
The part us not expensive, approx $10. Easy to replace, on the outside of the RV, remove the screws holding the inlet, pull out slightly and replace with the new. New caulking and done.
Ken
โMay-01-2021 09:33 AM
Dutch_12078 wrote:That's not a temporary fix, that's permanent! ๐
a quick temporary fix is to just screw a garden hose plug into the fitting.
โMay-01-2021 06:24 AM
Dutch_12078 wrote:
If flushing the check valve doesn't fix it, a quick temporary fix is to just screw a garden hose plug into the fitting. If that's not on hand, an inline garden hose shut off valve or even a common 'Y' adapter with shut offs will work.
โApr-30-2021 07:05 PM
agesilaus wrote:
Are you guys saying that the fresh water tank is pressurized?? I doubt it. The pump takes a suction on the tank the water is pulled thru the pump and comes out pressurized.
โApr-30-2021 05:21 PM
โApr-30-2021 05:17 PM
Bobbo wrote:wa8yxm wrote:JimR 1 wrote:
When mine leaked it was some sand or crud that got in the valve on mine there is a stem inside that I push in against the pressure and that flushes the valve out.
But I have also replaced two
JimR
The "I have no clue where they got their brains from" folks will holler that "OH you will break it if you do that" (Not true) but here is a fact.. It's already broken.. You might fix it, or you might not but worst case is you don't fix it
You depressurize the system first. If you don't, there is a CHANCE that the ring washer will be pushed out of place. Not always, but sometimes. If you depressurize first, there is not enough force to push the ring washer out, but you still get water backflowing out of the valve.
โApr-30-2021 08:10 AM
โApr-30-2021 05:34 AM
JimR
โApr-30-2021 03:58 AM
JimR
