class c upper clearance lights
SM49
I have a 2004 Four Winds 28 class c, the upper front clearance lights don't work. no power to them, ground is good, all of them work if I feed power to the drivers side light, does anyone know where the wiring would run to feed these lights
14 REPLIES 14
BFL13
Just means a longer wire to the nearest working light and more length of white Gorilla tape!
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
SM49
I was thinking of running a new wire from the light switch at the dash but have not come up with an easy way to do that
SM49
none on the sides, just front
BFL13
SM49 wrote:
Also there are no other lights close to these ones
You said the five fronts, so there should be a working side yellow front on each side near enough.
Photo in Profile
Travelin2
Run a new hot wire and forget the old one.
John & Gloria
South West, Florida
2009 Leisure Travel Serenity
SM49
BFL13
I added the fix I did to previous post.
Photo in Profile
SM49
unfortunately I can't find where that wire comes from
BFL13
Ok, say the wire for pos is green like on some. Dowm below there will be a branching of green wires going up to the sections. It seems that branch's wire has come loose down there.
I fixed a problem like that I could not find the right way, by running a wire from the pos of the next section's nearest light to the pos of the dead section's nearest light. So now just one big section. Covered the joining wire up there with white Gorilla tape so it looks fabulous ๐Ÿ™‚
Photo in Profile
SM49
none of the five front upper lights have power, I used a booster pack to feed that section of lights. the wire that feeds them has no power & I don't know where it comes from
BFL13
They go in sections of pos wire around the top of the Rv. If one light in that section loses its pos wire connection the whole section goes but the other sections work. Pull each light in that section that does not work to find the "open".
Photo in Profile
SM49
All other lights work
Lwiddis
Has the water resistance been inspected and repaired if necessary?
Travelin2
They are in the parking light circuit have you checked to see if your chassis parking lights work? If not, I would check the parking light fuse for beginners.
John & Gloria
South West, Florida
