May-20-2014 06:42 AM
May-30-2014 06:45 AM
May-29-2014 01:56 PM
May-29-2014 05:20 AM
May-28-2014 09:38 AM
May-27-2014 02:20 PM
May-27-2014 01:05 PM
Bob Landry wrote:Chris Bryant wrote:
You should read 12 volts between the yellow (Y)terminal and the Blue (B) terminal on the upper unit- this is from the thermostat. If you do have 12 volts there, you can try jumping the freeze control (the small sensor that sticks in the coils). If this thermister is bad, it will keep the compressor from running as well.
He said the unit was a Coleman. Do they also have a freeze sensor?
May-27-2014 11:01 AM
May-27-2014 10:58 AM
May-27-2014 10:22 AM
May-27-2014 10:08 AM
May-23-2014 08:44 AM
May-22-2014 03:45 PM
