xyzHollyxyz
Jun 17, 2016Explorer
EsoxLucius wrote:
While all 12 volt nominal solar panels in parallel may be compatible, one of the panels is rated for 19.8 volts and the 17.7 volts. In parallel they will BOTH generate closer to the 17.7 volts.
Okay, to make it clear to me - any 12V panels wired in parallel will be compatible, but the power output will be closer to the one with the lower(est) voltage rating? Got it. (sure...)
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
