JimK-NY
Aug 30, 2018Explorer II
Confusion on battery charging
I am confused about the best practices for charging batteries.
For 7 years I had 300 AH of Lifeline AGM batteries, 270 watts of solar and a simple charging system. My old camper has a 110 volt charger that is not adjustable and factory set at 13.3 volts. I rarely plugged in so that was not really a consideration. My solar charger was also single stage and set at 13.6 volts. I was told that 13.6 volts was too high for a float voltage and my have shortened with potential battery life.
I now have a new pair of batteries and a 3 stage charger. Float is 13.3 and absorption is 14.3. Absorption is set at 2 hours. Often I use very little from the batteries but the charging is still at 14.3. Any passing cloud will reset the absorption time so I often see the battery charging spending most of the day at 14.3. Do I need to make some adjustments to prolong battery life?
