pascoscout
Dec 25, 2018Explorer
Connect Atwood AC-1351 to AGS
I recently received my new toy hauler that was custom built. One feature I wanted was to have the generator automatically start when the roof top AC unit comes on. To do this I had the installer put in a Xantrex SW 3012 inverter/charger and a Xantrex Auto Generator Start controller. What I expected to see was the AC unit to be powered via the main AC panel and a low volt connection from the AC unit on the roof to the AGS on one of it's thermostat trigger leads. After going through the electrical system what I have found is the installer wired the AC units to run through the inverter with no direct connection to the AGS. It's below freezing here now so it's not easy to test the AC but what I am assuming will happen is the AC will come on and then drain the battery down to a point the AGS fires up the generator. While this may work it really isn't what I wanted.
So after this long story what I am really after... has anyone been able to get a signal from the Atwood AC-1351 to trigger an AGS unit? The Atwood has an integrated control panel (may be able to be removed and wall mounted) that has 4 wires running to the units main board. My assumption is I would need to figure out which wires send the signal to fire up the compressor (or may just the fan since it would always be on if the compressor is on) and connect those to the AGS, which in turn would tell the generator to turn on. If anyone has done this I'd really appreciate some pointers. Thanks!
