westend
Apr 30, 2017Explorer
Yes, you can and I did that exact thing.
![](http://i.imgur.com/w0iovqWl.jpg)
Any time you have wire connected to a power source in a vehicle or trailer, there should be some sort of circuit protection for the wire.
FWIW, I have possibly a similar situation where the converter, inverter, and solar controller have their own circuit protection. I chose to use a 150 Amp mega fuse at the battery's positive (+) post to protect that circuit.
If you are worried about the intrinsic damage from the fuse if it should blow, encase it in some clear shrink wrap or, as Mex advocated once, spray on some urethane crack filler. I don't worry about it since the batteries are in a box and that is a catastrophic fuse.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
