- pianotunaNomad IIIHi,
Many of us prefer to DIY. Shops are notoriously slow and often expensive. I've had good but EXPENSIVE service. For example $154 for an oil change--when I provided the oil. - scottsniderExplorer IIThank you all for your post, I got the trailer from a PP not a dealer and he used it just to sleep in while doing a house remodel. I will take the trailer in for a new awning soon and have them check it out and go from there. This is a 2004 trailer so its possible that converter is shot, I did not check the fuse yet (dumb me) for not checking that first. After the shop checks it our I will post what is known and what is the next step, again thank you all for your help.
- wa8yxmExplorer IIIYOu just described a failed converter,
scottsnider wrote:
Best to have someone look at the issue.
Thank you all for your help, as for the meeter I honestly don't know what to put it on. When it comes to electricity it either works or don't, I don't like getting shocked and have. Ok when I hooked up the trailer at home to 110 the Refrigerator works and the hydraulics (HiLo trailer) but the lights barely came on, and that is with the battery connected. I got a battery maintainer and all is good and bright (lights), that is why I wonder if the converter is working???????
If you post the converter model number we could suggest a better replacement to ask your service technician to install. Do not get a WFCO.- BFL13Explorer IISeems the converter is not working. Best to go back to the dealer to get them to show you how it all works to get it going again. Then you can do it yourself next time.
If not possible to do that, just know that the converter is with the power centre where the 120v breakers are and the 12v fuse panel is. The converter is on one of those breakers. Snap on and off.
(First make sure the other 120v things in the RV work except for the converter of course)
You could have the reverse polarity (RP) fuses on the converter or on the nearby fuse panel blown. When the dealer put the battery in for you to take the rig home, he could have wired it backwards first time, then wired it back properly so now everything 12v works on battery, but the converter needs new RP fuses.
The "battery disconnect switch" and the "battery fuse" are ok from the evidence that you are getting 12v into the rig. - scottsniderExplorer IIThank you all for your help, as for the meeter I honestly don't know what to put it on. When it comes to electricity it either works or don't, I don't like getting shocked and have. Ok when I hooked up the trailer at home to 110 the Refrigerator works and the hydraulics (HiLo trailer) but the lights barely came on, and that is with the battery connected. I got a battery maintainer and all is good and bright (lights), that is why I wonder if the converter is working???????
- Converter runs full time as long as you have the main cord plugged into a power source. If you have a battery switch you should move it to the in-use or on position.
You can just assume the converter works until it obviously does not. Or you can get a basic voltmeter and know that it works.
The 12 Volt Side of Life - cavieExplorerThere is a 15 amp 120 volt breaker feeding the converter. There are 2 "Reverse polarity fuses on the conveeter protecting the battery. there iS 12 VOLT INLINE FUSE WITHIN 6" OF THE BATTERY.
- RJsfishinExplorerIf your RV has a batt meter in a monitor panel, it will show if the converter is working.
- traviscExplorerFlip the 120 breaker for the converter, plug everything in make sure the 120 stuff works, then put an volt meter on the 12v fuses and see if you get 12v, use the converter body for ground and the fuses for 12v. Flip breaker and take the same measurement. Our converter went out and was putting out low voltage , only figured it out after buying a refrigerator board I didn’t need, I have the meter plugged into the 12v side and the more 12v things I turned on the lower the voltage went. Best converter.con fixed that for us
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
