โJun-23-2022 09:06 AM
โJun-25-2022 05:27 PM
โJun-25-2022 04:58 PM
โJun-24-2022 06:39 PM
โJun-24-2022 06:20 PM
Itinerant1 wrote:
My personal choice is a programmable inverter/ charger but my use is much different than most.
If I was downsizing and was going to stay with a converter than it would be one that Time2roll suggested in the 3rd post of this thread. I do have one of those converters hanging in the front compartment just disconnected from the system.
โJun-24-2022 06:16 PM
โJun-24-2022 06:08 PM
Itinerant1 wrote:pianotuna wrote:
Hi Gdetrailer,
I agree. Li are FUSSY.
They can work well.
I'll never own them as I camp in extreme cold.
They're not that fussy, my last hookup to a power pole was Nov 3rd last year for a night when there wasn't a boondock spot. Just solar and an occasional hold over from the generator during spring. Can't be that fussy. ๐
โJun-24-2022 05:57 PM
โJun-24-2022 05:02 PM
pianotuna wrote:
Hi Gdetrailer,
They can work well.
โJun-24-2022 04:24 PM
mpvuk wrote:theoldwizard1 wrote:
Any QUALITY converter/charger will have a specific setting for LiFePO4. Use it !
Personally, I would just eliminate the converter and buy an inverter/charger/automatic transfer switch.
New to this so hopefully replying in proper format...all LFE specific converter/chargers I've found have a 14.6V bulk phase. My battery mfg says to stay at 14.4 or less in bulk. Are there LFE chargers that start at 14.4? Regarding an inverter/charger, I already have a 2200W pure sine wave inverter that Works great. My best value seems to be using existing inverter and upgrading the converter.
โJun-24-2022 02:55 PM
โJun-24-2022 01:23 PM
Gdetrailer wrote:And the PD charging the LFP will not need that water, provide twice the power, and live through three sets of FLA.
I thought the idea of LFP batteries was to eliminate "maintenance" and hassle :h
Looks like you signed on to a lot of work and hassle :S
MY FLA requires a simple plug in and forget and once a year check and add water if needed :B Maximizing my enjoyment of my RV without the work.
My PD takes very good care of my FLAs yr round and keeps them in good working condition that takes them well over 10yrs of life.
โJun-24-2022 11:50 AM
โJun-24-2022 11:32 AM
3 tons wrote:
FWIW, LFP Simple Rules I live by - JMO
1) Except for occasional cell re-balancing, no need to fully recharge a LFP on a โwet-cell likeโ routine basisโฆ
2) Monitor closely the last few percent of recharge to 100% SOC thru to end of cell-balancing activityโฆ
3) Post cell-balancing activity, discontinue Boost charging (avoiding the longer term) - shut-off 12v converter (at breaker) and thereafter run minor 12v loads from the battery (this still supplies active 120v for larger appliances). When off-grid, LFP can be supplemented with harvestโฆ
4) For long term storage, disconnect and store LFP somewhere in the mid-SOC range (60-40โish % SOC range).
3 tons
โJun-24-2022 10:41 AM
