Ohio_Engineer's avatar
Jun 19, 2015
Cracked AC plastic cover
Discovered a number of cracks around the screw holes on the plastic cover of my Dometic Duo-Therm unit.
I have written Dometic asking what type of plastic they use as I want to use proper method and materials.
Different plastics require different adhesives or methods i.e. thermoplastic not same as thermo-setting.
I am expecting them to tell me to buy a new cover but thought someone here might know the answer.
I can do adhesive and I also have equipment to melt the plastic and reinforce with the correct type plastic if I knew what the plastic was.
PVC, ABS, PP, HDPE etc
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 10, 2025
