paulcardoza
Apr 04, 2016Explorer
CUMMINS ONAN 5500 strange problem.
Hi all,
We had a major power failure at our CG this weekend and we had to fire up our generator for the first time. 2014 Cyclone TH
So I checked to make sure it was filled with oil. Went got 20gal of gasoline and filled the tank.
Primed it per the instruction manual.
Fired right up, but as soon as I released the start button it stopped. Repeated that a bunch of times and it would run as long as I held in the start button, but would immediately stop when I released it.
SO..... I went outside and tried starting it from the switch on the genny itself. Worked perfectly and ran for an hour.
Later on I went through the same routine. It would not stay running when using the inside switch, but after going outside to start it, it ran the entire night.
Am I looking at a simple bad switch? Or something more concerning?
Any ideas would be welcomed and appreciated!
