ydoggy
Apr 20, 2014Explorer
DC compressor fridge power usage question
Hey guys - Looking for some help on a fridge topic. First post and have been reading as much as possible on this forum as well as others on the topic... has been very helpful.
Quick summary of my question and shared experiences from the public: Will I get at least 4days of fridge usage before depleting battery capacity with the following conditions:
-Lance 815 (small camper)
-100W solar (non-mppt charge controller)
- ~200AH (2x 6V)LA battery
- Pacfic NW weather: typically overcast with camping under tree cover so temps at a high of 80F with lows around 40f... ballpark.
-Conservative usage, minimize opening door, preconditioned contents, etc.
Fridge options:
-roughly 3cubic ft capcity (fire damaged fridge was a Norcold N300)
- 2-way (12v/120v) with Danfoss compressor
- Looking at Nova Kool R4500, Dometic CR1100
Long dissertation:
I have a small camper (Lance 815) which came with a 3-way Norcold fridge. Beyond the typical frustrations (level/temp stability), the propane lines were poorly routed and chafed a hole. This caused a small fire when I started the fridge the other day. Fortunately, I was able to identify and put it out before the entire rig went down with only permanent damage to the fridge and the vent (minor damage to the TPO roof). I always had concerns on fire safety of the 3-way setup, but one could sympathize that I will not go back to a 3-way fridge.
I've been looking at alternative options and the Danfoss 12V compressor fridge alternative is really appealing. I think it improves on my issues with the absorption fridge, but I may have power limitations and wanted to get feedback from the general public that has similar exposure to this setup.
I've read anywhere from 1-5A consumption on 12V (12-60 AH) and obviously conditions can take it to either of the extremes. I've also read duty cycles average 30-50%. Taking 30% as a more realistic number and the 60AH max, that would put usage at about 12AH to 18AH per day from my batter bank. Let's assume 20AH for safety factor, mathematically I would get 5days of fridge capacity without factoring in solar and no other power usages. Let's take this theory of getting 5days (or 20AH) from the compressor fridge and put it aside for a moment.
Before looking at my solar capabilities, let's assume that my other power usage is about 10AH per day for non-fridge usage. Now with the 100W solar that I currently have, this would replenish, or at least minimize the draw on the battery banks. I do have the option to upgrade to an additional 100W (or 200W) solar bank with a possibility to upgrade with an MPPT controller. If it legitimizes the compressor fridge I would take this route as well. I'm not interested in a generator.
So total daily consumption would be 30AH which would get me a hair over 3days of usage. With 100W solar panel, this could get me anywhere from zero to 64AH (8hrs @ 8A). Does this math add up? Would you recommend a 2nd 100W panel with MPPT controller?
Keep in mind, this is a small camper (Lance 815) so having a 200AH bank is pushing the capacity of the camper along with putting 200W solar on the top. I will upgrade to a larger camper, but being the first one, I would like to get complete use out of it (learning) before I upgrade.
The target is to dry camp 4 days without moving. Do you guys think this is doable? Anyone with similar experiences?
Thanks for any useful comments and suggestions.
Fridge options:
Long dissertation:
