When I tested cyclability of Trojan T-105 Golf car versus floor scrubber batteries in the early nineties (32 batteries each type) it was found the golf car batteries significantly out cycled the scrubber battery.
= They lasted longer and the difference between the 2 exceeded 15%
The significance was attributed to excess acid of the T-105
The scrubber was designed to fit floor scrubber machines -- a very limited amount of room. Per cubic inch of space taken the scrubber batteries gave significantly more ampere hours at the ten hour rate and significantly less at the 100 hour rate than the golf car battery.
No studies were conducted with improperly maintained batteries of either type.
