- 2oldmanExplorer IIAll you use is lighting?
- RLS7201Explorer III believe the best bang for the buck is two 6 volt golf cart batteries from Sam's Club or Costco.
Richard - MFLNomad IIOP...you need to give more info, as to use? If just for RV park, always shore power, or boondocking sometimes? Lots of good options depending.
I use Interstate brand 12V RV/Marine due to mostly shore power hookup availability.
Jerry - Off the shelf?
https://www.us.sokbattery.com/product-page/sok-12v-206ah-lifepo4-battery-bluetooth-built-in-heater
Home built can be an especially good value.
https://www.18650batterystore.com/products/eve-lf280k
https://www.18650batterystore.com/products/jk-bms-4-8s-12v-jk-b2a8s20p - Connor24ExplorerI use it for lights and refrige while boondocking. Refrige running on gas.
- pianotunaNomad IIIbest all around battery is SiO2. Pocket book "ouch".
First report I've seen on facebook of someone who disconnected their Li battery in the fall at 50% state of charge. Temperature was -5 c (23 f)at the lowest. Now they have two expensive door stops. - Old_DaysExplorer III am planning to buy 2 Renogy 100 amp hour batteries from Amazon for the trailer they are $189 dollars each.
Connor24 wrote:
That's it? A used car battery would handle that.
I use it for lights and refrige while boondocking. Refrige running on gas. - Grit_dogNavigator
Richard
This. - MFLNomad II
What? Com-on 2old, lets be nice! :) If he is boondocking, at least suggest using a couple actual deep cycles. Many seem to think a couple 6v golf cart batteries paired is a good choice.
Jerry
