DustyRooster
Aug 08, 2023Explorer
dougrainer wrote:
IF you have the tstat I posted link too. IF you have Fan speed set to Hi or Lo, then IF you have 120 available the roof AC fan will come on. to STOP that you set the Fan speed to AUTO and when on furnace the roof AC fan will NOT run. Doug
@dougrainer
This suggestion looks to have worked! Per previous post, the fan was set on "high", and it called the HP for heat assist. Per your suggestion, when I set the fan to "auto", only the propane furnace was called.
This is the exact behavior I was looking for, and it was just a tstat setting!
These forums come through yet again!
Thanks @dougrainer for the solution, and all for the feedback/suggestions.
-DR
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
