- prichardsonExplorerEasiest solution is to not fully extend. I have a dark colored awning and found that if you stop extension when the roller is slightly higher than at the sidewall it is actually cooler underneath than at full extension. This allows the hot air to escape rather than being trapped at the apex.
- MFLNomad IIWith my Dometic 9100, on my FW, with awning fully extended, I can put my 8' step ladder under the hanging flap, and still clear by a couple of inches.
It takes a fair pressure to pull down lower, and lock knobs, but will lower a lot.
When first starting to extend, it actually goes up, past level, before extending further, lowering at full extension to about a foot lower than at sidewall.
Jerry - SnotrodExplorerWhen fully extended, it is angled down quite a bit.
RV is new to me. 2013 Four Winds 31F - Not sure if this is your model. Look at page 5.
Dometic power awning manual
Model number is commonly on one of the arms - MFLNomad IIWelcome to the forum!
We don't know age or history of your RV, but too low is not normal, if installed correctly. Has it always been like this? Is this a recently purchased used RV?
Since we have little info, no picture, I'll guess the gas struts may be failing?
Jerry - Not sure of your make and model, but some awnings have adjustable limit switches to change where it stops.
- bukhrnExplorer IIIAngled slightly down could be a good thing if it's raining.
- Is the awning level when extended or is it angled down?
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
