Dometic DM2652 fridge not working
p598738
Was on the road two weeks ago and everything was fine. I am getting ready to leave for Florida and the fridge is not cooling. I put it on auto for several hours and got nothing. I am attached to shore power. The light in the fridge comes on when I open the door. Hoping it is an internal electrical problem, I switched to gas. Frige is turned on and switch set to gas. I can hear the flame burning. So far, nothing. Any suggestions ? Thanks.
Paul D. Woodman
14 REPLIES 14
Old-Biscuit
p598738 wrote:
It is working !! The leveling was the issue. Thanks very much for the help.
Good news!
Now remember.......if rig is set up off level DON'T turn fridge ON
It's OK to be off level as long as you DON'T use fridge OR operate slides if any.
Everything else is OK off level.........you can run furnace, use water heater etc. Just NOT the fridge.
p598738
Paul D. Woodman
p598738
I moved the RV to a level area. I'll check to see how it's doing later in the day and post. Thanks for the advice.
Paul D. Woodman
fpresto
While your home refrigerator has a compressor to compress the cooling medium; RV refrigerators use the absorption method. The fluid is heated either by propane or an electric heater and turns to gas. The gas rises up the tubes, cools and turns back to a liquid absorbing heat. The liquid falls by gravity back to the bottom and is reheated and the cycle repeats. There are no pumps involved. Off level and the fluid does not have a straight flow back through the tubing.
USN Retired
2016 Tiffin Allegro 32 SA
ktmrfs
Old-Biscuit wrote:
p598738 wrote:
The RV is not level. Should it be to be using shore power ???
Level doesn't matter concerning shore power, battery power etc.
BUT IT MATTERS when operating fridge.
Absorption fridges use gravity/heat to cause cooling medium to properly flow.
Off level operation will cause improper flow.....insufficient cooling whether on electric or propane.
This can cause crystallization which will cause blockage and KILL the cooling unit.......Damage is accumulative!
x2. if it's not level enough for you to sit, walk, sleep in without noticing the "off level" the it isn't level enough.
2011 Keystone Outback 295RE
Old-Biscuit
ktmrfs
check to make sure the shore power 120V breaker hasn't tripped.
p598738
Paul D. Woodman
Old-Biscuit
You can not adjust temp control.......your fridge has a pre-set temp control that is for both electric & propane. The thermistor in food section can affect temps (6-8*F).
The freezer section has to cool down first before you will see any cooling in the food section
This can take several hours.
You do have the RV 'level'....correct?
p598738
I think the thermo is only for the cooling part of the fridge (not the freezer). The outside temp is mid 60s (here in Maine).
Paul D. Woodman
camperpaul
What is the outside air temperature?
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
ferretgrandpa
Make sure the thermostat didn't get bumped
Medical reasons took us off the road
98 GMC 2500
RBW Lil Rocker 15K
08 Flagstaff 8526 RLS
p598738
I think it was on electric overnight. I am going to leave it on gas tonight. Thanks.
Paul D. Woodman
Poppy___Nana
How long have you had the fridge turned on? It can take a good 8 - 10 hours to cool down!
Leo & Kathy
Upstate, NY
in the Adirondacks
2013 Rubicon 2900 Toy Hauler
2008 - Ford F250 Super Crew 4x4
